Микрофон головной
Sennheiser HSP 4-EW-3 Beige
94 350 руб.
    Достаточно
High-quality condenser cardioid neckband mic for vocal and speech applications. Individually adjustable. Integral wind/pop shield . Easily interchangeable and combinable components thanks to modular design.
Features:
  • Excellent feedback rejection;
  • Microphone includes a detachable cap as integral wind/popshield;
  • Individually adjustable to all head sizes;
  • Neckband design keeps the microphone clear from shirt-collar or clothing;
  • Twist-proof microphone boom (Ø 2.0 mm), can be attached to the left or right side;
  • Microphone boom is adjustable in length and angle;
  • Flexible gooseneck section;
  • Connection cable can easily be interchanged;
  • All metal parts coated in a physical vapour deposition process;
  • Can also be used with the omni-directional HSP 2 boom microphone.
In the box:
  • Microphone;
  • Neckband holder;
  • Cable;
  • Foam wind protection;
  • Plastic case;
  • Documentation.
94 350 руб.
