High-quality condenser cardioid neckband mic for vocal and speech applications. Individually adjustable. Integral wind/pop shield . Easily interchangeable and combinable components thanks to modular design.
Features:
- Excellent feedback rejection;
- Microphone includes a detachable cap as integral wind/popshield;
- Individually adjustable to all head sizes;
- Neckband design keeps the microphone clear from shirt-collar or clothing;
- Twist-proof microphone boom (Ø 2.0 mm), can be attached to the left or right side;
- Microphone boom is adjustable in length and angle;
- Flexible gooseneck section;
- Connection cable can easily be interchanged;
- All metal parts coated in a physical vapour deposition process;
- Can also be used with the omni-directional HSP 2 boom microphone.
In the box:
- Microphone;
- Neckband holder;
- Cable;
- Foam wind protection;
- Plastic case;
- Documentation.
