Проигрыватель винила Pro-Ject T2 Super Phono Walnut Rainier
75 000 руб.
Код товара: 150034
    The Pro-Ject T2 Super Phono vinyl turntable has everything you need to satisfy not only beginners but also experienced vinylophiles. The device is made on a MDF chassis, the size of which is increased in comparison with the models of the younger T1 series, and thanks to the laconic design and high-quality exterior finish (black or white lacquer, or natural veneer) it looks very solid. All controls are located on the side of the case.
    Key Features:
    • Electronic switching of the disk speed
    • Oversized MDF anti-resonance chassis
    • 9-inch tone arm with pre-installed Sumiko Rainier MM pickup
    The Pro-Ject T2 features a 10 mm thick, 1.7kg glass platter. It is mounted on a subdisk, which in turn is connected to the pulley of an AC motor. The drive is powered by a proprietary quartz frequency stabilized oscillator. The Pro-Ject T2 Super Phono has an electronically switchable record speed of 33 1/3 or 45 rpm. An interesting feature of the model is the use of a new 9-inch lightweight aluminum tonearm. It is mounted on a precision bearing. Shell is integrated, which ensured the elimination of possible resonances. The unit is supplied with a Sumiko Rainier MM cartridge already installed.
    The tonearm utilizes a spring-loaded anti-skating system. The counterweight is nickel plated, giving the unit a professional appearance. The main “highlight” of the Pro-Ject T2 Super Phono is the high-end built-in phono stage (which is reflected in the name of the model). It is made on a large printed circuit board, with symmetrical placement of channel components - in fact, the principle of dual mono is realized here. Precision components are used in the corrector circuit, and RIAA-correction is made separate for HF and LF bands. This solution provides additional reduction of noise and distortion. If you wish to install an MC cartridge on the player, this unit can be disabled.
    The Pro-Ject T2 Super Phono comes with a transparent dust cover and a felt mat. Also included in the accessory kit is a proprietary cable for connecting the turntable to an external phono stage or the line input of an amplifier (if the built-in circuitry is used).
    In the Box:
    • Turntable
    • Sumiko Rainier MM cartridge
    • Adapter for singles
    • Connect it E phono cable
    • Dust Cover
    • Manual
    Pro-Ject
    Встроенный фонокорректор
    Интерфейс подключения
    rca
    МДФ
    Материал тонарма
    карбон
    Межблочный кабель
    съемный
    walnut
    Скорость воспроизведения
    33, 45
    Тип звукоснимателя
    MM
    Тип привода
    пассиковый
    Тип фонокорректора
    MM
    Тип шелла
    съемный
    Управление
    ручное
    Австрия
