Combining simplicity, robustness and elegance, the NorStone ESSE AV perfectly embodies the Norstone brand philosophy. Designed to blend naturally into any interior, this audio-video cabinet showcases your equipment without ever stealing the spotlight from your installation.
Its black epoxy-coated steel structure ensures optimal rigidity, while its tempered glass or wooden shelves offer both a beautiful finish and excellent resistance to heavy loads. Designed to accommodate both a television and a complete hi-fi or home cinema system, the ESSE AV cabinet meets the needs of audiophiles and film enthusiasts alike.
The four sides of the unit are open to provide easy access to your devices' connections and ensure effective natural ventilation. The result: optimal performance of your electronics, without the risk of overheating.
The NorStone ESSE AV cabinet stands out for its versatility. It can accommodate a television, home cinema amplifier, Blu-ray player or network box, as well as a turntable, CD player or hi-fi amplifier.
Dimensions:
- External dimensions (W x D x H): 1100 x 400 x 530 mm
- Top shelf (W x D): 1100 x 400 mm
- Internal shelves (W x D): 1040 x 400 mm
- Useful height between shelves
- Glass finish: 190 mm
- Wood finish: 199 mm
Package includes:
- NorStone ESSE AV black/walnut.
Please note: the height between shelves differs depending on the finish (glass or wood). Remember to check compatibility with your electronic devices before purchasing.
