The Norstone Eden Vision is more than just a piece of furniture; it is a complete and sophisticated home cinema solution. Designed to accommodate an ultra-short throw projector, the Lumene Eden Extra Bright 240C motorised screen and a sound system, it offers elegant and discreet integration of all audiovisual components.
A piece of furniture designed for integration and performance.
The Eden Vision cabinet stands out for its carefully designed architecture. Its central niche is dedicated to the integration of an ultra-short throw projector, ensuring a clean and functional installation. Its front panel, covered with black acoustic fabric, allows sound to pass through while cleverly concealing a soundbar or several speakers. The side and central storage compartments, equipped with gas-lift doors, can discreetly house a complete sound system.
The design combines robust and refined materials: a high-strength melamine structure and a black tempered glass top, combining strength and contemporary elegance. The whole unit is designed to blend harmoniously into a modern interior, while maintaining a sober and timeless design.
The Motorised Slider: precision and ease of use.
To optimise projector installation, Norstone offers the Motorised Slider as an option. This motorised platform allows you to adjust the position of the projector with millimetre precision and memorise the ideal setting to ensure a perfectly framed image every time you project. This device eliminates tedious manual adjustments and ensures smooth and efficient setup, enhancing user comfort and installation reliability.
The Eden Extra Bright 240C screen: immersion and discretion.
Designed specifically for ultra-short throw projectors, the Lumene Eden Extra Bright 240C screen is the centrepiece of the viewing experience. Its ALR (Ambient Light Rejection) fabric is optimised to reject ambient light and maximise contrast, ensuring a bright and detailed image even in un-darkened rooms. With a 240 cm base, it offers spectacular large-format projection, perfectly suited to a domestic environment.
Fully motorised, this floor screen unfolds smoothly when projection is required, then disappears completely into the Eden Vision cabinet when retracted. This invisible integration preserves the simplicity of the space and underlines the aesthetic and practical appeal of the concept.
A comprehensive and elegant solution.
The combination of the Eden Vision cabinet, optional motorised screen and Eden Extra Bright 240C projector defines a new approach to home cinema. Every detail has been designed to combine practicality, performance and aesthetics. Once installed, the technology disappears in favour of the visual and audio experience, recreating the magic of cinema in the heart of your home.
Features:
Eden Vision Cabinet
- Structure: High-resistance melamine, tempered black glass shelf
- Front panel: Black acoustic fabric
- Dimensions: L2634 × H510 × D600 mm
- Maximum load: 50 kg
- Delivery: Flat-packed (unassembled)
- Packaging: 3 boxes (including screws and tools)
- Finish: Black
Motorized Tray
- Finish: Black
- Maximum load: 25 kg
- Dimensions (closed): L610 × H58 × D370 mm
- Dimensions (open): L610 × H58 × D710 mm
- Net weight: 11.7 kg
Eden Extra Bright UST Screen
- Brand: LUMENE (high-quality screen)
- Projection surface: ALR (Ambient Light Rejecting)
- Gain: 0.5
- Viewing angle: 140°
- Features:No hotspots
- Anti-yellowing, anti-dust, and anti-wrinkle treatment
- Black light-blocking backing
- Black borders
- Compatibility: Ultra-short throw projectors only
- Housing: Black lacquered steel
Compatibility:
Motorized Screen Recess
- Exclusive integration for Lumene Eden Extra Bright UST and Lumene Eden Extra Bright Lt models.
- The screen completely disappears into the furniture for a seamless and elegant integration.
Ultra-Short Throw Projector Recess
- Optimized dimensions: H224 mm × D429 mm × W900 mm
- Designed to accommodate most UST projectors on the market.
- High load capacity: Up to 50 kg.
Motorized Slider (Optional)
- Motorized sliding platform for ultra-precise projector adjustment.
- Dimensions: L610 × H58 × D370 mm
- Maximum extension: 340 mm
- Position memory for perfectly framed images every time.
Dedicated Soundbar Space
- Spacious acoustic compartment for discreet integration.
- Dimensions: H140 mm × W2500 mm × D185 mm
- Compatible with most premium soundbars on the market.
Side Compartments for Speakers
- Generous compartments for Hi-Fi speaker integration.
- Dimensions: H460 mm × D400 mm × W830 mm
- Ideal for a powerful sound system, fully integrated behind acoustic fabric.
Package includes:
- NorStone Eden Vision 240 Black.
