The unique sound of DAVIS ACOUSTICS in this in-wall speaker! The thin-edged cover allows the speaker to be virtually hidden in the ceiling/wall.
Key Features:
- 16.5cm Kevlar coaxial bass driver + 25mm soft dome voice coil tweeter
- The tweeter is housed in an adjustable frame (+/- 20°)
- Easy to fix, just make a perfectly round hole with a diameter of 209 mm
16.5cm Kevlar coaxial bass driver + 25mm soft dome voice coil tweeter. The tweeter is housed in an adjustable frame (+/- 20°), so you can adjust the direction of the high frequencies and direct the sound wave perfectly towards the listening area.
The IN-WALL loudspeaker, as its name suggests, is a speaker to be recessed into a wall or ceiling. With its small footprint and discreet design, it can replace a more conventional loudspeaker.
The 165 RO PRO is easy to fit, all you have to do is make a perfectly round hole 209 mm in diameter, but to help you out, a paper model is supplied with all the speakers.
Next, simply remove the protective magnetic grille. Once the grille has been removed and the loudspeaker wired (either by soldering or by terminal block), all you need is a Phillips-head screwdriver. All you have to do is turn the 4, 6 or 8 screws (depending on the model), so that small hooks clamp the speakers in place.
INWALL loudspeakers like the 165 RO PRO don’t pretend to replace bookshelf loudspeakers, whose load volume and crossover have been optimized, but special care has been taken to ensure their sound quality: woven Kevlar fiber driver, adjustable textile dome tweeter.
The intrinsic characteristics of the loudspeakers used mean that they can operate with either almost infinite or reduced rear load. Depending on the rear volume, the level of low frequencies will be slightly modified.
In the Box:
- In-wall speaker
- Manual
